69 Firebird, Pont350, bad valve guide
I have oil on my #3 spark plug.
Compression is great. Vacuum test wavers quickly at 20-21. I recently switched to Rotella T oil for it's ZDDP content. Then I read this in a Hot Rod article on the subject: "The drawback, if any, would be on a high-mileage engine where blow-by can cause detergent to accumulate in the combustion chamber, possibly contributing to detonation." http://www.hotrod.com/techarticles/e...h/viewall.html So my solution is to spray Seafoam's "Deep Creep" into the combustion chamber through the spark plug hole fairly frequently to prevent the detergent from accumulating. Is this a fair idea? Also is it correct that I cannot really do anything about the leaky valve guide without pulling off the head as well? |
Oil on #3 plug.....
Hi,there is an adapter that fits on the electrode end of the plug,usually used on engines that burn oil, this adapter places the electrode end further up into the head, i dont know where you can buy them,i would try NAPA.
If oil is getting into the chamber, there is going to be carbon build-up over time. The oil alone can increase the chance of detonation, regardless of any build-up, though. Best bet is to fix the problem rather than treat the symptoms- as I'm sure you realize. |
So my friend tells me that I could replace the valve stem seals and that that action would probably fix my oil problem. I would do it in a similar manner to this.
http://www.youtube.com/watch?v=ob_4-F-m1FI My friend also told me the redneck method of keeping the valves from falling would be to stuff a bunch of rope in the cylinder, then bring the piston up to tdc. Would that work? |
I take it you didn't read my post very well? If your not going to read what I said then perhaps I shouldn't have wasted my time posting. Furthermore, the "redneck" method with rope is far better than pressurizing the cylinder with air, as if you just happen to tap one of the valves it drops.
| valve guide cutting, dual valve springs | ekacpuc | Engine | 3 | 08-12-2011 06:39 AM |
| Valve Guide Changes... | hallamwillis | Engine | 3 | 04-17-2007 05:59 PM |
| valve guide cracked | 67camarokid | Engine | 3 | 10-22-2005 01:38 AM |
| valve guide diameter on 350? | fiscus | Engine | 1 | 09-14-2005 05:24 AM |
| Can the dual coil valve springs on a BB destroy Valve guide seals | Auto-Part | Engine | 4 | 11-25-2003 05:23 PM |
