69 firebird trans issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2011, 05:27 AM
I have a TH400 with 3.55 rear and 25" tire. car tachs 3500 at 55 mph. calcultor says I should be at 2700 rpm. any suggestions on whats wrong? trans and converter are new 10/2010. 1800 stall. has anyone pur a 200r4 in a 69 firebird?
Old 11-12-2011, 08:02 PM
1badLemans's Avatar
Hey john, I know for a fact that you must change the speedo gear in the trans when you swap the rear end gears to match. I don't have a link to post but they are easily found on the net. They are color coded for your gear like tan, blue, green etc for different gears 3.23, 3.55, 3.73 etc. I would check that part first and see if it's a different color than it's supposed to be. Looks like a lil plastic gear. Good luck
1997 Trans Sport fan issue. el pollo General Rodding Tech 4 08-20-2011 08:16 PM
trans done have a small issue! cudablack2004 Transmission - Rearend 6 07-24-2011 08:59 AM
85 pontiac firebird trans am rhibbsiii Introduce Yourself 2 02-22-2006 03:30 PM
67 firebird trans swap speedfrk3 Transmission - Rearend 2 12-11-2002 05:08 PM
89' Firebird Trans Question tminnie Transmission - Rearend 1 10-29-2002 01:43 AM
