Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Interior
  #1
Old 05-25-2006, 06:13 PM
brokens brokens is offline
69 Firebird upholstery
I am installing new foam and seat covers in my 69 Firebird Convertible, purchased from Classic industries. It seams like the foam is really quit deep to hogring the uphostery through and seems that there would be a deep seam when installed. Does anyone have any good ideas on getting the hogrings through the foam and attached to the seat back? I was thinking of making a sort of wire staple and sticking them through the seat and then pulling the upholstery back into the foam slot.
Thanks,
Blayne
Old 05-26-2006, 01:57 PM
creativeinteriors's Avatar
creativeinteriors creativeinteriors is offline
Stitching or grease I love it
re: 69 Firebird upholstery
I forgot the pattern on the firebird so a picture of the interface would help.
How thick are the wires for the listing pockets? And are they spring steel? Spring steel will bold the tension better.
Also when you hogring the frequency of rings you put in defines how much undulation you get from the listing. The more you put in the better.
A shot of the seat will help to tell you what order to install the rings as there is a pattern to give you the best hold and tension.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "69 Firebird upholstery"
Will An Olds 455 Engine Fit In My 69 Firebird daveh Engine 5 11-11-2005 01:38 AM
i want too change a 69 firebird intoo a 69 camaro traviss10_999 Introduce Yourself 1 07-03-2004 12:17 PM
69 firebird with olds 455? rjrj4 Engine 8 12-18-2003 12:48 AM
69 firebird rim sizes??? Grey80Ghost Suspension - Brakes - Steering 2 09-18-2003 03:31 PM
69 firebird wheels with tires for sale fletch69 Engine 1 09-02-2002 12:42 PM
