-   -   69 Fmx (http://www.hotrodders.com/forum/69-fmx-61566.html)
Gassman 04-19-2005 07:27 PM
69 Fmx
I need to replace the seal for the shifter shaft in a 69 FMX, do I have to remove the valve body first. I think I can get the shaft out by removing the front part of the valve body. Do the steel lines just pull out of the body. I think the part I am talking about is the pressure regulator.
willys36@aol.com 04-24-2005 12:31 AM
Maybe these guys can answer your question.
Crosley 04-24-2005 12:05 PM
remove the valve body.
the transfer tubes simply pull out. It is not an easy task since under the vehicle you need 3-4 hands to line stuff up
Gassman 04-25-2005 08:54 PM
I installed the seal and oring Sat. All went well but you were right. I removed the front part of the valve body but I couldn't hardly hold everything to line it all up at once. Thanks for the reply.
