69 Fmx - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2005, 07:27 PM
69 Fmx
I need to replace the seal for the shifter shaft in a 69 FMX, do I have to remove the valve body first. I think I can get the shaft out by removing the front part of the valve body. Do the steel lines just pull out of the body. I think the part I am talking about is the pressure regulator.
Old 04-24-2005, 12:31 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Maybe these guys can answer your question.
Old 04-24-2005, 12:05 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
remove the valve body.
the transfer tubes simply pull out. It is not an easy task since under the vehicle you need 3-4 hands to line stuff up
Old 04-25-2005, 08:54 PM
I installed the seal and oring Sat. All went well but you were right. I removed the front part of the valve body but I couldn't hardly hold everything to line it all up at once. Thanks for the reply.
56 chevy front seat 56-210 General Rodding Tech 2 08-12-2005 03:35 PM
Ford FMX Transmission RAW Transmission - Rearend 10 08-02-2004 10:05 PM
Heidt's\ TCI or Fat man ? for a 56 F100 56f100 Suspension - Brakes - Steering 18 09-16-2003 05:41 PM
Borg Warner T 56 Silver Transmission - Rearend 1 05-13-2003 10:22 AM
'56 Pickemup or '89 'burban hotrodtodd Hotrodders' Lounge 4 12-27-2002 05:07 PM
