Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 69 GM Column Horn Problems
Old 12-31-2004, 09:25 AM
Campbem Campbem is offline
I am in desperate need of help on this one. I have a 38 chevy pickup with a 69 GM column in it. Am having trouble getting the horn to work. I know I have the wires right from the fuse box because I can put a simple push button starter switch on and it works. I know the problem is in the steering column and in particular, the horn button assembly. I had a grant steering wheel on it when I got the truck (couple months ago) and I put a GM adapter on it and Colorado steering wheel on. I replaced all the horn parts that I think will make the horn work but I am not sure I got everything back in right. Does anyone have a diagram of the set up? Also, not sure if I am grounding it correctly. I have a green wire running fron under the horn cap that I grounded to the 3/8 screw in the adapter. Hooked the hot lead from the horn button to the horn lead running through the horn cam? Where did I go wrong?
Thanks for your help!
campbem
