Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 69 GM Column Horn Problems
Old 12-31-2004, 10:56 AM
Campbem Campbem is offline
Thanks guys,
I really am not at all electrically literate. I have a wire running up from the horn cam spring and pin to the middle button located on the rear of the horn button. Is this correct? The pin makes contact with the little button located on the turn signal cam setup, underneath the horn cam. Is it possible that when I cut the pin to fit in the cam that it could be too short. The brass spring still makes contact with the pin as it moves.
I have green wire running from the back of the horn button, which is off center that I ran to a zinc coated 3/8in. screw that is threaded into the floor of the GM adapter. Is this right?
Again, thanks for your help and I apologize for my stupidity. I am learning as I go. I guess thats what rodding is all about... it's frustrating at times but when it all comes together, it feels great!
Mark C.
