Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 69 GM Column Horn Problems
Old 12-31-2004, 11:02 AM
bracketeer's Avatar
bracketeer bracketeer is offline
489 Lemans
Last journal entry: Street Legal
you lost me
take the green wire you say is your horn wire and touch it to metal. horn should blow. If it doesn't. It is a problem downstream not in the steering wheel horn button. Check wire running through column with an ohmmeter. If its ok. Hot jump the horn relay. If horn doesn't blow. Relay is bad.
