69' GTO no park lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2006, 02:42 AM
I have headlights reverse lights, brake lights and turn signals but no park lights at any time. The fuse blows when switched on. Any ideas to trouble shoot this
Name:	Gto front.JPG
ID:	12285   Click image for larger version
ID:	12286   Click image for larger version
ID:	12287   Click image for larger version
Name:	Gto wheel.JPG
Old 05-16-2006, 03:17 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
Look for a short on the park lamp line going to the lamps and heater control lamp.
Remove the bulbs , turn on the switch, does it blow the fuse again? If so, the wire or socket has a short.
Unplug the wire from the light switch, ohm out the Orange wire to ground, it it has continuity (without bulbs) separate the wire from the front and rears..( find the rear harness plug, unplug it)
Measure the rear to ground first, if good,
Measure the front to ground, if good
Measure the orange wire to ground ..If good
The switch is defective in park.
Doc
Old 05-16-2006, 03:28 AM
You must work nights like me. Thanks for the advice, I'm going to go and try all this now and see if I can get it working. I keep you updated.
Old 05-16-2006, 03:36 AM
Doc, should I pull the heater control bulb and all park lights front and back before testing?
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
69 gto mhol160 Electrical 1 11-21-2005 03:19 PM
Double Pole Park Lights horvath Electrical 5 08-14-2003 09:05 PM
wiring harness for '69 GTO cleaner21 Electrical 1 08-13-2003 08:25 AM
Custom tail lights for a 69 camaro????? chevyelc81 Body - Exterior 1 02-24-2003 07:59 PM
