Hotrodders.com Streetbeasts lawsuit Beat the Beast -- defend free speech!
Streetbeasts lawsuit fundraiser
Goal: $10,000. Amount raised: $4,047.
Get the latest news on the lawsuit.
Thanks donors!
Click here to donate, or see more details about donating.
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 05-25-2003, 09:57 PM
Phat 69 Phat 69 is offline
Post 69 impala brake swap
What cars should i be on the look out for as far as donor parts wise to go from all manual drums to power with front discs?? thaks
Old 05-28-2003, 12:32 AM
jimfulco jimfulco is offline
Post
69 & 70 would be best, because they have single-piston calipers. Parts (pads, etc.) are readily available. 65-68 would work, but they have 4-piston calipers which tend to leak (fixable but expensive) and you don't have much choice of pad material. They are also extremely rare.
[ May 28, 2003: Message edited by: jimfulco ]</p>
Old 05-28-2003, 05:23 AM
Post
I know i'll need the following
1. spindles and everthing on them
2. proportioning valve
would a also need the master cylnder too??
Thanks
Old 05-28-2003, 06:47 AM
troy-curt's Avatar
troy-curt troy-curt is offline
Shop Owner And Troll Hunter
Post
Yep you need the master cyl. and booster and proportioning valve.
Old 05-28-2003, 07:58 AM
Post
thanks
Old 05-31-2003, 09:35 PM
black66's Avatar
black66 black66 is offline
www.airriderz.com
Post
Phat are you going to lower your car?? There are a lot of ways you can lower your impala. If you are going to lower it. You can buy a drop spindle that allows you to use 72 Chevelle disc brake setup. Or if you are using you stock spindle. You can get adapter plates that allow you to use 72 Chevelle disc brakes.... Try these spots for Impala parts..... I have a 66 Impala and these shops have eveything you will need for the disc brake swap....
www.impalas.com/
<a href="http://www.performancesuspension.com/]http://www.performancesuspension.com/[/URL]
Old 11-30-2003, 07:24 AM
Car Nutz Car Nutz is offline
I just picked a 69 Impala yesterday, and it too has front drums.
Do You have to replace the spindles, or can Disc hardware be add to them after removing drum equipment?
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2010. All Rights Reserved.
