69 impala weatherstrip changing - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2009, 08:43 AM
On a 2 door coupe,anyone ever remove/replace the rubber that is on car,NOT DOOR and seals windows when their against it. Mines ratty. Want to replace but before I start tearing I want some inside info please
Old 12-16-2009, 09:21 AM
DanTwoLakes's Avatar
Wiki Edits: 22
I'm not sure, are you talking about the belt weatherstripping that rides against the window as it goes up and down? It is attached to the top of the door panel. Those are held on by staples either through the felt or underneath the rubber flap. After you remove the staples, you can put the new weatherstripping back on with new staples, small stainless steel screws, or pop rivets either aluminum or stainless steel.
CLICK HERE
Old 12-16-2009, 12:50 PM
CLICK HERE
That which goes around door frame on car. NOT on door. Comes up from just above hinge and over your head and down the front of the rear window to another flat pad that screws to the metal just below rear window
Old 12-17-2009, 06:12 PM
APOLOGIES ON THE EXPLANATION
I was right when I said it started above front door hinge but wrong when I said down rear window. Two seperate pieces. This one keeps going along top of rear window and back of it and disappears down inside. Seals top edges of both windows to car. Anyone ever change one on anything similar to a 69 impala? LOOKS NIGHTMARISH
THE PARTS
http://cgi.ebay.com/ebaymotors/69-70...mZ110454691159
Old 12-20-2009, 06:00 AM
Okay
Has Anyone At Any Time Ever Changed any Late 60's,early 70's Chev 2dr Hardtop Roofrail Weatherstrip. Ever In The History Of Man, On Anything??????????
Old 12-20-2009, 07:32 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Yes, a couple.
Old 12-20-2009, 04:28 PM
Originally Posted by 1ownerT
Yes, a couple.
care to elaborate?
pics of my 69 Impala 1eyedjak Hot Rod Art 25 10-15-2007 10:36 AM
69 Impala rally wheel hub caps 1eyedjak Body - Exterior 2 07-27-2006 07:59 PM
1969 IMPALA Engine Mounts a problem??? IMPDOG69 Engine 7 02-28-2006 05:49 PM
69 Impala master cylinder godsMistake Suspension - Brakes - Steering 1 09-23-2005 08:32 PM
1961 Impala speedneedy Electrical 1 01-18-2003 11:13 PM
