69 mustang race fuel pump/filter location
Guys,
I'm re-doing the fuel system on my 69 fastback due to a dead Holley pump. I have a worked 302 with the 125 shot of nitrous on it, but I'm planning on upgrading the motor so I'm doing a system that will allow me to do that. I think I have the system planned, but I'm having difficulty deciding where to place the fuel pump and filter. Previously I had them in between the leaf spring and inside quarter panel, but this is tight as you can see from the pics. Also, the folks from Barry Grant said that the pump is gravity fed and needs to be lower than the tank, but the tank is pretty much the lowest thing on this car (on most cars) so I'm not sure where it can go. The old pump has been working right where it is for 20 years so I'm not sure if I need to worry about that, so long as I keep enough gas in the tank to keep the gas pushed up to the filter. If this is a big concern then I'm thinking that I will need to maybe go with a fuel cell. The system I'm planning needs a 10AN return line and the guy from BG said it has to go in in the top of the tank. Can it be very close to the top but just on the side, or does it truly need to be in the top? What have you guys done?
Mike
