Thread Tools Search this Thread share on Facebook
  #1
Old 12-13-2011, 11:33 AM
Nuck Chorris Nuck Chorris is offline
69 Pont, 2bbl to 4bbl, MPG questions
I've got a stock 69 Pont 2bbl 350. I found some deals on craigslist for a non EGR Edelbrock Performer manifold and a Edelbrock 500 CFM carb. Gaskets, brackets, all told it looks like I would spend 250 to convert. I get 16-17 MPG on the freeway right now with the stock 2bbl set up. Would converting improve my highway mileage?
Register now (free) or login to remove ads
Old 12-13-2011, 12:10 PM
cobalt327's Avatar
cobalt327 cobalt327 is online now
WFO
Wiki Edits: 1,616
I seriously doubt changing to an Edelbrock 500 cfm 4-bbl carb and intake will improve the mileage.
The 2G Rochester your engine came with isn't the best carb for mileage, but being a 2-bbl it will obviously use less fuel when you accelerate hard than a 4-bbl. If you were to use a Rochester Dualjet (which is the primary side of a Q-jet), you might get a little better mileage- but there's no intake that will fit that carb to your engine. That leaves using a Q-jet 4-bbl carb. It could get a little better mileage- at least potentially- if you could stay out of the secondaries. But that's a tall order, the secondaries start to come in before the primaries are fully open.
Bottom line is what you have now, provided it's working right and tuned to the engine, is about as good as it gets unless you were to go to EFI. The engine tune and general vehicle condition will also effect mileage, but the biggest factor is still your right foot.
Old 12-13-2011, 05:13 PM
Hotrodrobert Hotrodrobert is offline
If you set up the Eddy carb, it will get some better than the stock 2g does. Best carb is a Quadrajet that is set up for your car.
NO other carb will get better than a Q Jet set up right and driven properly.
Get a vacuum guage and learn to drive by that. You will be amazed.
Old 12-13-2011, 05:23 PM
adantessr's Avatar
adantessr adantessr is online now
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
X2 on the Q-jet. I proved it to my self a few times in days gone by. A friend once bought my used 2bbl set up in hopes of improving economy. He found that his mileage was better with the 4bbl that he took off.
Old 12-13-2011, 05:34 PM
boatbob2 boatbob2 is online now
boatbob2
Last classified ad: 1982 Chevy C-10 pickup
Milage.......
Hi,i had a 64 olds,with a 394 engine and 2 brl,got 5 mpg,swapped it for a manifold and 2 -500 carbs,milage went to 12 mpg...
Old 12-13-2011, 06:12 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Last journal entry: Fresh paint
Wiki Edits: 9
Bob, two four barrel carbs out did a single 2 bbl for mileage...you're kidding, right?
''Life's tough, Pilgrim, and it's even tougher if you're stupid.''---John Wayne
Midnight Sun Street Rod Association
Old 12-13-2011, 06:16 PM
cobalt327's Avatar
WFO
Wiki Edits: 1,616
Hi,i had a 64 olds,with a 394 engine and 2 brl,got 5 mpg...
That's not just because it was a 2-bbl carb. It had to have other problems. Unless you drove it WOT all the time. I got better than that (about 8 mpg) w/a Potiac 428 w/Tripower- and it was driven hard.
Old 12-14-2011, 10:17 AM
boatbob2
5 t0 12 MPG.......
NO,thats not kidding,i thought i had a hole in my gas tank,that 2 brl carb,DRANK gas,the 2-4 brls outdid that 2 brl by 7 MPG. i know its hard to believe,but its the truth... that was on a trip from San francisco to Fort Lauderdale in 1964,car was NEW,drove across the states at about 85 mph...and NO AC...
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "69 Pont, 2bbl to 4bbl, MPG questions"
ThreadThread StarterForumRepliesLast Post
Car worth more with a 4bbl rather than a 2bbl?ArrowheadGeneral Rodding Tech408-18-2008 08:42 AM
Going from 2bbl to 4bbl. Hp increase?Sir JoabEngine804-28-2008 06:17 AM
2bbl to 4bblwranglr88Engine107-20-2007 12:11 AM
2bbl to 4bbl conversioncalimstng66Engine703-02-2006 04:28 PM
4bbl v 2bbldeleteallEngine407-07-2002 07:12 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
