Thread Tools Search this Thread share on Facebook
  #1
Old 12-18-2008, 09:12 PM
beeroh beeroh is offline
69 Pontiac 350 head swap
I have a 69 Custom S and it currently has the stock 350 in it. I have a pair of #64 heads that have the larger valves. Will swapping out heads work?
Register now (free) or login to remove ads
Old 12-18-2008, 09:17 PM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1,659
welcome to Hotrodders.
ask your question in the engine forum....this is the introduction forum
Old 12-19-2008, 09:52 AM
poncho62's Avatar
poncho62 poncho62 is online now
Last journal entry: 51 Ford F1
Wiki Edits: 5
moving it........Have you checked the valve size?....Chances are they are the same.
In the words of Walter Cronkite..."And that's the way it is."
Ontario Rodders
Old 12-19-2008, 06:19 PM
WDCreech's Avatar
WDCreech WDCreech is online now
Grumpy Old Goat Herder
The 64 heads do have bigger valves and will give you a true 9:1 compression, which is almost ideal for pump gas. Go for it and good luck. If you have anymore questions, I will address them on this forum.
Old 12-19-2008, 11:58 PM
TANGO TANGO is offline
Your Stock 1969 Pontiac should have #17 or #47 Heads on it . They are 72-75cc chambers with 196" in /1.66" ex Valves your right at 9.1 C/R with them . Now the #64 Heads are of a 1970 455 . They are 87cc chambers with 2.11" in / 1.77" ex Valves . These #64 Heads are great castings but save them for a 400 or 455 build . They will lower your C/R and them Larger valves are not needed for that Small Bore 350 . You will lose Power with them . I would have your stock heads rebuilt . Pontiac 350's are tricky to build with there 3.880" Small bore
Old 12-20-2008, 07:53 AM
nitro_baller4692's Avatar
nitro_baller4692 nitro_baller4692 is offline
floppers forever
here's a site for poncho heads.hope this helps
http://www.boyleworks.com/ta400/psp/heads.html
Old 12-20-2008, 11:06 AM
WDCreech's Avatar
I agree, the 64s are worth a lot to someone building a high performance 455 for street/strip and the smaller valve heads would be more responsive on a 350, but it would be wise to have screw in studs installed.
Old 12-22-2008, 03:53 PM
well thanks for everyones replies.. I was wondering if the 64 heads would of been a good swap because the 350 has a cam with a .454 lift so I was thinking that heads with larger valves would give it more HP..
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "69 Pontiac 350 head swap"
ThreadThread StarterForumRepliesLast Post
El Camino Engine - 350 Chevy or 455 Pontiacbjam2Engine1608-07-2007 03:45 PM
Chevy 350 engine swap – motor mount question78transamEngine406-04-2007 05:57 PM
El Camino Engine - 350 Chevy or 455 Pontiacbjam2Engine1701-06-2007 09:11 PM
HELP: Olds 350 swap in a 85 RegalTorxEngine304-12-2006 03:55 AM
350 to 305 engine swapjrm123180Engine1003-28-2004 04:03 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
