Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 69 Right Hand Drive
Old 04-26-2003, 08:59 PM
woodz428's Avatar
woodz428 woodz428 is offline
Troll Hunter
Arrow
Seems like a lot of work, but you should be able to get parts from an Aussie car, The Falcon (the understructure, not just the name) was used until at least the mid to late eighties so you should be able to get most of the stuff from down under (steering gear,pedals under dask support,etc.). Like I said,quite a job. You could also get a European rack of some sort and adapt it, if you just want the look. Ford did export models, but I think you would be hard pressed to find (and afford) the parts used or new.
