I had a '69 Torino Cobra with 3.50 gears, and I don't remember RPMs being all that high when cruising. However, the 3.91 rear end will run a little higher RPM, which will hurt your gas mileage. With 3.50's and a 428 engine my speed was about 125 mph when I hit 5500 rpm (approximately the RPM for the engine's max HP rating).
These Torino's do not have a lot of extra clearance for larger tires. You can bolt on helper springs in the rear to bring it up a little, but in the front you may have to put spacers in the coils or use taller springs. My car had F70-14's on stock offset 6 inch rims and they fit very well with no lift. Most folks who had 15's on Mustangs used an F60-15, which were actually shorter than the 14" tires. 15" tires were not an option on the '69 Torino. Bruce |
thanks bruce,
got the marti report back and the car was ordered with 300 gears. should be a-ok (a little sluggish, if anything). i'm going to use the original rims for now and put 235 60's on the back. i agree, there isn't going to be much room for change in the rear tire wells without installing some air shocks. if i don't have to build the engine i'm going keep this one as close to original as possible even though it kills me to. i'm looking at a 72 cutlass and a 79 camaro to hop up right now. the torino is too rare and too original to screw up. |
| torino | SALLY | Introduce Yourself | 1 | 08-13-2007 10:44 AM |
| What is a 69 Torino GT worth? | loyter | Hotrodders' Lounge | 5 | 05-17-2007 05:25 AM |
| 69 Torino GT | anthonyc | General Rodding Tech | 1 | 12-14-2006 04:28 PM |
| 1975 torino | Milford Nick | Introduce Yourself | 2 | 03-15-2006 01:07 PM |
| '70 Cobra Torino | boss1b | Introduce Yourself | 3 | 02-06-2006 07:27 AM |
