'69 Z28 Front Marker Light Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2010, 05:47 PM
Joe G's Avatar
I'm working on '69 Camaro for a friend and a question has come up that I'm sure some of you guys will know the answer to.
On this particular car, are the front side marker lights supposed to blink with the turn signals or not?
Mine are not.
About every GM vehicle I've ever seen with side marker lights has them wired to blink with the turn signal (and blink alternately with the turn signals when the park lights are on). I know how to make it work the way I expect it to (ground the marker through the turn lights), but I would like to verify that that is how they worked from the factory. Maybe this was some exception or something???
Thanks...
Old 07-26-2010, 06:41 PM
302 Z28's Avatar
No.
Vince
Old 07-26-2010, 06:52 PM
Joe G's Avatar
Thanks.
Joe
gasser front spring question new_rat_rodder Suspension - Brakes - Steering 4 12-20-2009 04:39 PM
69 impala differential strength question sooper Transmission - Rearend 3 12-10-2009 04:44 PM
front rotor question 49fordp/u Suspension - Brakes - Steering 7 09-17-2009 02:26 PM
dummy light question 60mpala Electrical 1 03-27-2003 07:11 PM
front hub question??? HemmiGremmie Transmission - Rearend 2 08-09-2002 06:17 PM
