Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 6K To Spend, What Motor?
Old 01-09-2010, 12:49 PM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Wiki Edits: 9
If you are going to use it as a daily driver, the 2004R is a good choice, adjusting the rear gears and tires to match are also a good compliment, and another good choice would be to go to EFI of some sort to get every bit out of every drop of fuel you can get. Even a 1/2 mpg is an improvement, at the very least.
