Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 6v to 12v conversion
Old 08-09-2004, 02:42 PM
tm454 tm454 is offline
Tazz
6 Volt to 12 Volt changeover
All the light bulbs, head lights, tail lights, turn signal, dash and overhead lights all changed to 12 volt bulbs. Then the coil and the charging system will need to be brought up to date, 12 volt alternator and battery. If you use a 12 volt generator you'll need a 12 volt voltage regulator also.
Tazz
Rat Rods Rule!
