Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 6v to 12v conversion
Old 08-12-2004, 11:12 AM
dubie's Avatar
dubie dubie is offline
Last journal entry: the goods
You need a 12V starter, alternator and battery. While you're at it, you can grab a 12V distributor and coil from a junk yard for about $20, unless you go with an HEI whcih I would do. And that will run you about $50 used. So if you get all your parts from Bucks there in Winnipeg, it could be done for pretty cheap. What kind of engine are we talking about here? inline 6 or V8? I imagine it's for the 58 you are lookig at so it would more than likely be a 235 inline 6.
