6v positive ground to 12v negitive ground
I have a 48 Plymouth special deluxe and i am very interested in converting to a 12v negative ground system and dont know where to start im not used to the older cars its a new a venture for me, I would really appreciate if someone could help me out. thank you in advance
.......keeping the same engine/gauges - if so, you will have some problems. Starter will run backwards though a 6VDC starter will work on 12VDC - as long as polarity is right, generator - will need to be replaced or better yet, install an alternator, gauges will need to be replaced or modified along with all senders. The lights - they don't care except they need to be 12VDC, the ignition system, will need a different and 12VDC coil. New condenser for neg ground, tho the points don't care either. New 12VDC ballast resistor. Radio - wont work (if it has one).
Now, if you are changing the drive line to something modern - it will all be neg ground - but the gauges and senders still need to be changed |
Could i Just keep everything but the generator the same and use a voltage box to drop all of the original wiring and everything back to the 6v pos. ground i dont mind everything on the 6v it runs and works fine. i just would like some modern accessories. i looked and i found to use a 10SI alternator. instead of the generator
Go back and read my previous post - it will tell what will or wont happen
| Postive ground but negative coil, strange one | Nightfire | Electrical | 21 | 04-19-2006 05:20 PM |
| Positive ground fuel pump? | HotRodMan | Electrical | 2 | 04-05-2006 11:18 AM |
| determining positive from ground | MeligN | Electrical | 13 | 02-09-2006 10:40 PM |
| Spacers behind fan? | moodier | General Rodding Tech | 14 | 10-06-2005 08:08 AM |
| When working on a positive ground truck... | Nightfire | Hotrodding Basics | 1 | 07-18-2005 10:21 PM |
