6volt positive ground swap to negitive ground? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2012, 01:22 PM
I'm Considering swapping from positive ground to negative ground. I plan in the future to swap to 12v as well. What all leads must be swapped. The car is a 52 dodge so obviously the full current ammeter must be changed, the coil, but what about lighting horns, blowers etc. Do relays care which way there grounded? Is this something I should even worry about before the 12 Volt conversion? I want to get the car running and driving the 12v conversion will be done next winter when I blow it apart for bodywork and paint. It has stock engine really stock everything. Thanks for your help.
Kris
Old 09-19-2012, 01:41 PM
starnest's Avatar
elkyholic
Last journal entry: Center Link Installed
I would have to see schematics and maybe inspect the wiring of the car to identify the changes needed to accomplish this change. On the surface it would seem like a simple change, just connect the old postive side cable to the battery's negative terminal and vice cersa, however, because of the way the circuits and components are wired and operate, there could be serious (unsafe) issues to deal with.
IMHO - a car with 60 year old wiring would be a candidate for a fresh wiring harness, with that in mind I would consult with painless wiring (or others) to identify new negative ground wiring harnesses and components to build a new electrical system. This avoids both, old wiring and conversion hazards. (BTW - I would change the ammeter over to a voltmeter).
Old 09-19-2012, 09:23 PM
Cape Cod Bob's Avatar
There is no need to change at this time. You would not see any difference. When you change to 12v you will need to get rid of the ammeter gauge and use a voltmeter gauge. You can get a voltage reducer at napa for ford cars as they kept 6v gauges into the 6o's and that part is still available. Gas gauge may need a reducer by itself and may need a 12v tank sender that is same resistance as gauge.
Old 09-20-2012, 07:32 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
electricity does not care
Right off. The starter won't work after reversing the polarity. It will run backwards.
Even if you have it rewired internally it will function exactly as it did in the original state.
Same goes for any motor. Generator and gauges also. Lights Ok.
To much involved for no benefit.
vicrod
positive ground ???? need help choirboy Electrical 9 02-25-2011 10:02 AM
I need to change polarity from positve to negitive ground Elwood_DR Electrical 10 10-13-2010 10:44 AM
6v positive ground to 12v negitive ground darksidecustoms Electrical 3 07-20-2009 09:29 PM
Positive Ground Stick Man Electrical 2 04-17-2007 08:29 PM
Positive ground maddogmodl Electrical 15 02-03-2007 11:49 AM
