6x D port head Flow Rate? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2010, 01:53 PM
Any one know the flow rate for stock 6X D port heads?
BT
Old 09-16-2010, 02:14 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
FLOW CHARTS- http://www.wallaceracing.com/ultimateflow.htm
1975-79 No. 6X (1975-76 400/455 & 1977-79 400 D-port)
Date cast: 0185 Grade: 2 (worn guides)
Valve sizes: 2.11/1.66
Intake volume (1 port): 154.0 cc's
Intake(S) Flow (cfm) Exhaust(S) Flow (cfm) Exh./Int.
.100 67 .100 51 .76
.200 112 .200 83 .74
.300 140 .300 96 .67
.400 158 .400 104 .66
.500 163 .500 110 .67
.600 167 .600 113 .68
Old 09-16-2010, 03:05 PM
That puts them about even with a stock 305????????
Old 09-16-2010, 04:39 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
There's a disclaimer at the beginning of the flow charts that warn to use the numbers mainly as a comparison to the other heads that were flowed on that particular bench. Then there's no mention (that I saw) of what depression they were flowed at, either.
That said, the flow on Pontiac heads generally are not very good. My 468 Pontiac w/ported 6X-4's- with 2.11/1.66 (i.e. stock) valves made a max of 444 HP @ 4950 RPM. These heads were not flowed, maybe someone w/software could extrapolate the flow required to make that HP. The cam was 0.500" lift w/234 @ 0.050" on a 108 LSA, as best I remember. CR was 9.25:1.
Old 09-16-2010, 05:29 PM
WDCreech's Avatar
Grumpy Old Goat Herder
cobalt, If those flow numbers that you posted were from an old HPP, those tests were done at 10 inches of water, so the numbers at 28" would be higher.
Old 09-16-2010, 06:41 PM
http://users.erols.com/srweiss/tablehdc.htm
They are showing a 6X-4 on this sight with flow numbers that are a little bit more believable.
.100 79/47
.200 139/92
.300 187131
.400 202/147
.500 211/154
SBC Head port sizes? Gearhead forever Engine 2 01-09-2009 09:57 AM
Bosch injetor flow rate NorthStar Engine 0 12-17-2008 02:00 AM
Cam Help black66 Engine 3 05-12-2003 07:15 PM
Stock eliminator 78 monte Engine 5 01-02-2003 06:10 AM
Head flow BobWebster Engine 4 12-06-2002 03:36 PM
