7 or 10 degree locks - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2010, 07:48 PM
yes if im switching from 7 to 10 degree locks, will I have to change my valves, or as long as I have matching retainers ill be all set
Old 07-22-2010, 08:25 PM
ericnova72's Avatar
More for Less Racer
Don't need different valves, You just need 10° retainers and 10° locks. Locks just need to match your valve stem size. There are +.050", standard, and minus .050" locks if you need to dial in spring installed heights (they just machine the lock ridge higher or lower).
Old 07-23-2010, 05:29 AM
BOBCRMAN@aol.com's Avatar
Is there a specific reason for the change? 7 degree locks work better for street engines. 10 degree locks are for high spring load, aggressive roller cam type profiles..
In addition to the plus and minus sizes listed. There are plus and minus locks in .020 and .030. Just don't mix them up with other off sets on the same valve stem..
Brake lights switch oldsmo Electrical 4 10-19-2006 11:23 AM
beehive retainer locks, issue ? Vortech 4.3 Engine 1 02-15-2006 07:08 PM
IGNITION and CAM TIMING sum87mustang Engine 3 07-11-2003 07:52 PM
Engine Vacuum is showing 10 and no higher? ataririder Engine 42 02-18-2003 07:12 PM
10 0/0 theory dinger Hotrodders' Lounge 3 09-12-2002 08:14 AM
