7.3 power stroke will not stay running until warmed up well - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2010, 09:08 AM
Is it possible this could be the power valve? When it gets below 20 degrees it will run ruff and when I start driving down the road it chocks down for a while then it takes off and runs fine. Help
Old 12-12-2010, 09:25 AM
35terraplane's Avatar
Do you plug it in at night, even when mine is in my garage, and is heated but only to 40 degrees, and I back my truck up into the garage with the front end next to the door, mine wouldn't run very good, really rough if I didn't start it for a few days. Then the Ford garage told me to plug it in, they said that happens when the truck get a few miles, well I did And it run fine now, Just the little clatter until it gets oil running.
35terraplane Bob
Old 12-13-2010, 05:38 AM
bondo's Avatar
Ayuh,... You're feeling the heatriser valve closing, 'n opening...
Perfectly Normal...
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Big bore vs. Long stroke Blazin72 Engine 32 12-03-2006 04:12 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Torino wont stay running 79firebird350 Engine 4 05-20-2004 12:38 PM
Bronco will not stay running th2hh Electrical 8 10-10-2003 10:16 PM
