7.3L Powerstroke - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2012, 08:04 AM
7.3L Powerstroke
So here's the deal i live in wisconsin and i go down to visit family in north carolina all the time. my cousin has a 2000 7.3L Powerstroke and he's a little cocky. He wants to hook chains with my truck a 78 chevy with a carburated 350 and a 600 edlebrock carb. what can i do to tune the engine up to get more torque out of it, i know he'll probably pull me up and down the mountains but i just want to make it so i have somewhat of a chance. any suggestions?
Old 10-22-2012, 08:16 AM
hcompton's Avatar
Old & Furious
Do you have granny gear first. he may be in for a suprise. If so then you just need a load of wood in the back. also be sure to oil his tires before the competion and insist its on the street. No reason to make it a fair fight.
The heavy powerstroke will pull harder cause its got more wieght.
Old 10-22-2012, 08:32 AM
Wiki Edits: 27
cat engine
I have a friend that put a Cat Semi truck engine- Trans in his pickup, Axles out of a large motor home, trade trucks for a weekend ? wheel bearing grease on his tires works better.. lasts longer.
Old 10-22-2012, 12:40 PM
vinniekq2's Avatar
DO NOT PULL EACH OTHER ON PAVEMENT,,roflllll.a transmission will break somewhere
I would take that challenge with my 7.3.
Go off road,spin your back tires to gid a little hole,let him back up to you.Your truck weighs 7,000 pounds,with the back tires in a little rut and your brakes on,he wont even move you.when he digs a hole and cant move,charge him for a tow. The diesel also has a posi rear diff so that also helps
Old 10-22-2012, 03:00 PM
No granny but i do like the hole idea if he cant pull me that'll make him look bad too ahha ill load the bed up with logs and rocks though to add more weight thanks
Old 10-22-2012, 06:04 PM
BarryK's Avatar
It is not a matter of witch truck will come out of this in one piece, so we go too the question of, how will you get back to Wisconsin?
350, 7.3l, chevy, powerstroke, torque
cummings vs powerstroke powwowpow Engine 8 09-21-2012 12:59 PM
Powerstroke only goes backwards! Camaro1980 Transmission - Rearend 6 06-24-2008 10:33 PM
6.4L Powerstroke Blazin72 Hotrodders' Lounge 0 08-23-2007 12:55 AM
99 Powerstroke Blazin72 Engine 2 11-20-2005 10:22 PM
Powerstroke suprise 302 Z28 Engine 2 07-18-2005 10:49 AM
