7.5" 10 bolt posi unit - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2003, 11:06 PM
E.T. divided by $ spent= Speed
Post 7.5" 10 bolt posi unit
I bought a posi from a freind for $100.How can you tell with out installing it and tromping on it if its close to rebuild time??Can you visualy inspect it??
Also the diff is a 3.08 and down carrier.I'm told I can use gears for a 3.23 and up carrier with the use of a spacer is this true or do I have to buy a set of gears for the 3.08-down carrier??
If I gotta buy a new set,I'm lookin at either another set of 3.42s or upping to 3.73
Thanks
Old 02-06-2003, 02:03 PM
Post
Old 02-08-2003, 01:31 PM
New Member
Post
just curious how much HP that rear end can handle on a 2000lb car.....
thx
Old 02-09-2003, 02:09 PM
Post
My car should be pushing 325hp/365tq flywheel so I'll prolly be putting 250rear wheel HP to it.
My uncle had a Monza that ran 6.3 1/8mi on the 7.5" 10 bolt.Allthough that car did snap an axle once.
Old 02-10-2003, 06:34 PM
axle bastard's Avatar
you're killin me buck!
Post
if it is an old style eaton (with all the whirlygigs in with the side gears ind clutches)
i would run it till it pukes then scrap it.
over built rotating junk heaps they are.
i might have some used gears for that laying around, i'll check to see.
Old 02-11-2003, 03:44 PM
MI2600's Avatar
Member# 3287
Post
I've been doing similar research for my '86. I learned (I think) that you can either use a spacer or they make thicker rings gears that will fit the 3.08 & down unit.
Old 02-11-2003, 11:37 PM
Post
Axle bastard if ya got a set of 3.42s or 3.73s for the 3.08 and lower carrier let me know what ya want for them.Send me a PM.
I hAVEN'T LOOKED FOR ANY #S BUT i THINK ITS A gm POSI NOT SURE.
[ February 12, 2003: Message edited by: 78 monte ]
[ February 12, 2003: Message edited by: 78 monte ]</p>
Old 02-12-2003, 07:51 AM
Post
well.... i have a 7 5/8 from an s-10.
not a 7 1/2, sorry!
Old 02-12-2003, 03:11 PM
F-1Rodder's Avatar
Post
I have a 7 5/8" with 3.42:1 gears if you want it.
