7.5 or 8.5 rear end? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2014, 12:08 AM
Im trying to figure out if my truck has a 7.5 rear end its a 94 gmc sierra 4.3 v6 im going to start swaping an ls1 and wanted to swap the rear end to a 8.5 and add some gears to it ( if mines a 7.5
Old 06-10-2014, 07:11 AM
big gear head's Avatar
High Performance Rear Ends
S series truck or full size 1/2 ton? If it's a full size 1/2 ton then it's the 8.5 rear end. The 7.5 was not used in full size trucks.
Old 06-10-2014, 11:11 AM
Its a 2 door short bed
Old 06-10-2014, 01:18 PM
That doesn't tell me anything. Is it a full size 1/2 ton 1500 or is it a S15?
Old 06-10-2014, 05:08 PM
Wiki Edits: 31
Sierra is a full size. The Sonoma was the S10 variant.. so it has an 8.5" unless it's got the F44 package and then it would actually be a 9.5" 14 bolt
The Following User Says Thank You to matt167 For This Useful Post:
Rudyg1970 (06-13-2014)
Old 06-11-2014, 07:52 AM
Yes sir, Sierra does signify full size GMT-400 truck. RPO F44 signifies the "heavy half" that gets the 14 bolt 9.5" Semi Floating rear end.
If this is a 2wd Sierra, F44 will trigger the upgrade to 6 lug wheels, same as teh 4wd. The only 14 bolt 9.5" SF with 5 lug wheels was the 1990-1993 454SS, axles of which, are impossible to find.
Does F44 automatically get rpo Mt1 4l80-E? I'm guessing yes?
thanks
peace
Hog
The Following User Says Thank You to Hogg For This Useful Post:
Old 06-13-2014, 01:05 PM
Thanks, so then should I go ahead and add gears to this rear end itself?
Old 06-13-2014, 02:49 PM
What gears are in it now? What do you want to do with it? What transmission will you be using? How tall will the rear tires be?
Old 06-13-2014, 11:51 PM
It has stock gears I was thinking 3.73 gears im putting an ls1 that comes with a 4l60e im trying to keep the engine stock at first but later im going to add heads and mild cam
Old 06-14-2014, 06:40 AM
Wiki Edits: 31
Stock gears in a 4.3L is probably 3.73's as is. Best check your RPO codes to see
GM RPO Codes - Axle & Ratio Identification - Sierra Gear & Axle
Old 06-14-2014, 08:26 AM
I thought I had seen they where somthing like 3.41s or something around that, but also ita not a posi
Old 06-14-2014, 09:02 AM
You need to find out what you have before you make plans to change it.
Old 06-14-2014, 02:34 PM
Wiki Edits: 31
If it's a 3.42, the code is GU6. There are a couple 3.73 codes but I don't know what ones go to the GMT400 trucks.
Old 06-14-2014, 05:19 PM
Proud LOSER
3.42 to 3.73 is not worth the effort..... likely a big tire on it and an OD, at least 4.11's would be a good start. May even want a 4.56 depending on tire size.
Old 06-14-2014, 06:15 PM
I wanted 4.10s but one of my friends mentioned the fact that It was my daily driver
rear, rear axle upgrade, rear end identification, rear end swap
1953 Buick Special-front end rear end?? mbjeep Suspension - Brakes - Steering 8 12-06-2009 07:32 PM
stock 63 chevyII rear end vs. s-10 rear end david6chevy Transmission - Rearend 3 08-17-2009 05:36 AM
Gm 12 bolt truck rear end vs. car rear end '54 Pontiac Transmission - Rearend 6 02-05-2009 06:17 PM
4x4 12 bolt rear end same as 2wd rear end??? Ed ke6bnl Transmission - Rearend 2 05-24-2008 03:25 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 04:28 AM
