Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 02-28-2006, 12:07 PM
fumplet fumplet is offline
7 and 5/8 rear end drivers side axle leaks
Hi, I have a 7 and 5/8 axle underneath my 86 s-10 and it leaks at the axle seal. I replaced the axle seals before installing it....what all can cause a seal to leak? I did gouge a little of the axle using a seal puller but I got all the sharp edges off of it and used silicone to make sure it sealed....I also took sand paper and smoothed the axle to make sure it will seal. could this seal be the cause of my vibration at freeway speed........the vibration cycles on and off once every second when the vehicle is warm........kinda like a shaft that is out of balance like a drill bit not chucked right.......and yes I paid 300 dollars to have the driveshaft balanced..How far does one have to move the axle up and down to suspect a axle bearing?
Old 02-28-2006, 07:28 PM
jimfulco jimfulco is offline
re: 7 and 5/8 rear end drivers side axle leaks
Did you notice any grooving on the axle just inboard of where the seal rides?
Old 02-28-2006, 09:08 PM
Triaged Triaged is offline
 Triaged's barnstar
Having a bent axle or bad axle bearings can cause the seal (even a new one) to leak.
Old 02-28-2006, 11:09 PM
I did notice a slight groove but not a big one.....so I could tell where the old seal rode
Old 03-01-2006, 12:39 AM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Overqualified Underacheiver.
 M&M CUSTOM's barnstar
An "axle saver" seal and bearing will move the bearing and seal to a different part of the axleshaft surface, but will not help your balance/ vibration/ possible bent shaft issue.
Old 03-01-2006, 09:14 AM
Ok then where do I get the axle saver and seal?........also will this fix last very long?.........where does the bearing go?, in farther than the original bearing?
Old 03-01-2006, 09:33 AM
Just a note.........I had the same problem with the other rear end.too. The one I have now is a 7 and 5.8..............before I had the 7 and a half rear end..........and I also thought that replacing the axles and bearings would cure the problem.....but the drivers side still leaked........so either I am doing something wrong or hell I am just screwed with bad karma...I did notice that the new seals on this one looked like they were the right application..............the old seals were good and tight in there, how ever the new ones werent quite as tight.................as far as seal installation techniques.............isnt it ok just to tap the seal in place with a hammer as long as you dont warp the seal or go ape **** and whack the hell out of the seal?
Old 03-02-2006, 12:39 AM
M&M CUSTOM's Avatar
The axle saver bearing and seal can usually be found at any good parts place.
You can usually get the seal in place without killing it even using just a hammer and going around the outside in a circular motion with light taps and have no problems. It's harder to screw it up with a large socket or a block of wood though.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "7 and 5/8 rear end drivers side axle leaks"
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 07:33 AM
side exhuast exits or rear exits? 85CHEVY Engine 4 08-24-2005 03:14 PM
S-10 Rear end and tranny Andrew7dg Transmission - Rearend 2 12-11-2003 04:23 AM
Syclone Rear End Question bluesman123 Transmission - Rearend 6 11-18-2002 07:49 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
