7.5 Axle id and ? about narrowing using ranger axle shafts - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2009, 06:06 PM
johnhalabama's Avatar
Last journal entry: checking the clearance
I have a Ford 7.5 rear axle with disc brakes w/ abs.
Rear tag is:
S 268 A
3 27 75 9C 19 (3:27 7.5 open)
1) Any idea what it is out of ? I'm thinking 99 mustang
First of all it was free. I am building a 36 Dodge with a 280 hp jeep stroker engine/auto. I won't be racing it but may be doing some light towing for a 1000 lb tear drop camper. I plan on buying an Auburn posi and may go with the c-clip eliminators and use aftermarket alloy shafts.
( I know, I know, go with the 8.8 or 9". But it was free)
2) Can you take two 83-92 26-1/4" 28 spline axle shafts, narrow the housing and run these stock short axles? Will changing from abs to non-abs change any of the end spacing on the axle ?
Thanks for the help in advance guys.
John - Chesapeake, VA 1936 D2 2 Door Dodge Sedan
Old 07-23-2009, 07:32 AM
Anybody???
Any help on this???
Let me know. I really want to get going on rounding up some parts.
Thanks,
John
Old 07-23-2009, 11:16 AM
prostreet6t9's Avatar
Differential/Driveline
The exciter ring for the ABS is on the carrier,so it will not effect your axle's.The axle's your speaking of are from the 83 to 92 ranger.If I was doing the diff for you,I would probably try and talk you out of doing the C-Clip eliminator kit.They tend to be leaky and a pain for a streetrod. And once you install them,you can't go back.
Do you have your mind set on the auburn?
Old 07-23-2009, 01:32 PM
reply
I've heard that the c-clip eliminators tend to leak so I am a little hesitant to go that route. Weak link tends to be the track-lok Auburn has heavier parts and Detroit has worm gears I believe. I'm not set on any locker. I won't be loading up the rearend just want posi for towing if I need it.
Old 07-23-2009, 05:12 PM
You might take a look at the Ford Motorsports E7TZ4026A. It's a nice unit and it's all rebuildable if ever needed.It's a little less money that the auburn unit and the auburn's are NON rebuildable.
A nice set of axle's and a posi would do real nice and you wouldn't have to worry about leaks.
