7.5 in Ford rear end pinion offset - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2010, 06:59 AM
Hey,
I have a 1999 7.5 in Ford rear end ring and pinion gear set. I want build a test rig to run these gears and I need the pinion offset or distance between the pinion axis and ring axis. I believe this distance is between 1.00 and 1.25 in. Please share this information or where I can get the pinion offset.
Thanks,
David
Old 07-18-2010, 03:36 PM
big gear head's Avatar
High Performance Rear Ends
Measure the pinion gear from the center line of the shaft to the pitch circle. That will be the offset. This is adjusted after they are installed in the rear end housing by using shims.
Old 07-19-2010, 05:59 AM
This measurement is one of our problems. Two of us did this measurement and we are getting different answers; 1.00 in and 1.25 in. Ok, a big difference and reason for confirmation. Seems this is 'standard' information and available somewhere. Thanks.
Old 07-19-2010, 06:16 AM
You might want to get a 7.5 rear end that is assembled and measure the distance from the center line of the pinion shaft to the mounting surface of the ring gear. This will give you the distance that you need to make a test fixture. Be sure to make the test fixture adjustable.
Old 07-20-2010, 03:39 PM
Thanks again, we are working on this indirectly. Hopefully our pinion offset value will be 'good' (like 1.00, 1.125, or 1.25 in). Again, thanks.
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 06:43 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
7.5 rear end performance question 1BADSS-10 Transmission - Rearend 2 12-16-2004 07:45 PM
Converting Jag rear end to Ford 9" Jag Daddy Transmission - Rearend 5 12-25-2003 02:47 PM
Ford 9" Rear End Narrowing nightrain_rod Transmission - Rearend 3 11-30-2003 11:50 AM
