We're winning the case!
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 12-15-2004, 06:50 PM
1BADSS-10's Avatar
1BADSS-10 1BADSS-10 is offline
7.5 rear end performance question
Hi , I'm new to this bulletin board and was looking for a little help. I'm in the process of building a peppy smallblock for my s-10, my question is I know this truck is equiped with a 7.5 rear end will this rear end stand up to a 400+ HP small block or should i look into an 8.5 set up? Thank you for any and all help.
Old 12-15-2004, 07:15 PM
Tiresmoke7's Avatar
Tiresmoke7 Tiresmoke7 is offline
New Member
I think it will be ok as long as you stick with street tires due to the lack of traction. If you plan on using slicks I would say go with the 8.5 , especially if it is a stick shift.
Old 12-16-2004, 07:45 PM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
M&M CUSTOM's barnstar
Wiki editor
Last wiki edit: How to clean glass
Wiki Edits: 5
It will certainly hold up to the engine, but will drastically lose dependability with each smoky burnout, tire squeal, and heavy right footed takeoff.
It is certainly a dependable axle behind a 4 cylinder, and will live for many miles behind a 6, but will not take more than that without some degree of help.
I have read on other forums I belong to, the 7.5 can hold up to some amount of racing even behind a big block but the only thing going for those guys is luck.
The later S-10's used the corporate 8.5 inch, or you could swap a disc brake equipped 8.8 ford axle out of a late model Explorer.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
