7.5 Rear gear swap effect reliability? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2006, 06:37 PM
montea's Avatar
tryn to learn
i have a 82 Grand prix with a 350/350 2.73 10bolt 7.5 w/ 295/50R15's in the back. im just starting to collect all the parts to do a transmission and rear end swap this fall. ive picked up a 700r4 and right now im looking for some new gears. trying to decide between a 3.42 and 3.73. my motor is under 300hp. my original rear end came with 2.29 that im going to use again for the new gears. by swapping to a 3.42 or 3.73(found 3.42 complete rear w/gov lock or set of 3.73 gears for my stock carrier for cheap) how will it effect the reliability of the rear end?
Old 05-31-2006, 11:19 PM
Installing a Gov-lock will most likely diminish the reliability of your rear end. They have a reputation for grenading with only slight provocation.
Old 06-01-2006, 07:25 AM
montea's Avatar
tryn to learn
what about a simple ring and pinion gear swap from 2.29-3.73... am i going to loose reliability? im just trying to think and from what i understand the only thing that would take more beating is the axles? and maybe bearings?
Old 06-01-2006, 09:58 PM
I think anything past the pinion gear will be more heavily strained. I also think you have to change the carrier if you go from 2.29 to 3.73.
7 hours, 33 phone calls, &30 pages of Threads later... Rearend? Tranny? Need Guidance 68ChevelleFromHell Suspension - Brakes - Steering 19 01-13-2006 02:01 PM
changing my spedo gear to get right after rear end swap montea Transmission - Rearend 4 10-04-2005 04:33 PM
74 to 65 rear end gear swap? 65_Chevy Transmission - Rearend 4 06-26-2005 02:29 AM
Chevy rear end swap Truplayainfla Introduce Yourself 1 10-24-2004 12:07 AM
rear end gear swap Jared Engine 3 03-19-2003 09:46 PM
