7.625 GM Diff question???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2006, 01:59 PM
mattmanuel's Avatar
02,87,67,66,34 all Chevys
Last journal entry: Side project
Question: How are axle tubes secured to the center diff housing of a GM 7.625 10 Bolt? Are they just pressed in? I have one side that is a bit banana'd and was wondering if trying to replace the tube is worth the effort. I have a diff alignment bar, a lathe to create the bearing slugs for the 7.625 and a 50 ton press, so I would think I'm properly equipped. I have narrowed a few diffs before but never tried to replace a housing tube. Advice wanted, and greatly appreciated
Old 08-11-2006, 04:45 PM
larryblack's Avatar
Certified Lead Foot
They are pressed in with a spot weld. At least the ones I have dealt with are.
Save yourself a few $$ and headaches and find one that fits in the used parts yard. Prices run $150 to $350 depending on gear ratio, posi or not and local. If your tube is bent, the axle shaft is probably junk too.
460LE (??) Gm automatic Question schnitz Transmission - Rearend 6 05-15-2005 06:33 PM
Wheels and tires question 1978 GM G-Body. z3pr Garage - Tools 1 09-19-2004 04:03 AM
GM Aternator question please help rwruther Electrical 2 09-11-2004 09:15 PM
diff question carnell Transmission - Rearend 4 09-26-2003 09:27 PM
GM column size question 29 2dr sedan Interior 2 09-17-2003 06:06 AM
