I used a single diaphram 7-8"booster from a Ford Fiesta and it works Okay. It could be better on my 52 Chev PU. If you get a dual diaphram either size will work good. I didn't have any problem with header clearance.
Bigger boost is better with discs, But if you are concerned about clearance go with a dual diaphram 7".
An 8" single has about 50 sq inches of diaphram area, a 7" has about 38 sq inches and a dual 7" has about 70. sq in. Each inch of vacuum is good for about 1/2 psi, so you will get about 600 pounds of boost at the mc piston from a 7" dual ...450 with a 8" and 340 with a 7" all at 18" of vacuum. An 8" dual will give you about 850 #. The 8" single should be alright if you don't mind pushing the brake a little harder. If you are using the TCI pedal assembly for that truck, then it is a high ratio arm anyway, and your brakes will be easy enough...(about 6 or 7 to 1 IIRC.) I've installed the boosters with only a couple of inches clearance with no problems. Edit..I didn't see the post above where you said you were considering dual diaphrams. If you are using GM calipers use the 1 1/8" master. Hope this helps, Mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example Last edited by powerrodsmike; 02-16-2008 at 11:47 PM. |
Yes it is a good idea to install RPV's.
A prop valve is good to have as well, Speedway sells 2 brands of them for cheap. Mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
If the master cylinder is below the wheel cyliders or caliphers then you use a 10# RPV inline to drum brakes and 2# to disc brakes. This keeps them from sucking air around the seals or pucks as they retract and air entering the system. If the master is above the wheels then you don't need RPvalves. A disc drum master already has a RPV in the rear drum exit. Under the tapered brass seat where the line connects. You can check to see if there is one in the master by carefully inserting a paper clip into the master cly. brass line seat and feel for a rubber valve..
On a streetrod I always use the inline adjustable proportining valve, like Wildwood sells, in the rear line and I still think I could get away with not usining one on Disc-disc. On my truck using the Fiesta booster I mounted it back on the trans. crossover after welding on a bracket then used the original pedal with a 2' extension to the booster. It's called streetrodding or IE; make it work. LOL
| Brake booster troubleshooting... | cefolar | Suspension - Brakes - Steering | 10 | 11-16-2009 01:02 PM |
| Single Diaphragm Booster | Slant3 | Suspension - Brakes - Steering | 2 | 10-06-2005 07:37 AM |
| low profile tires for 15 inch Halibrand reps | peranaman | Suspension - Brakes - Steering | 3 | 06-28-2005 04:36 AM |
| brake booster size | pigjamelectric | Suspension - Brakes - Steering | 3 | 05-08-2005 08:44 PM |
| Booster Relocation Kit | ALASKAN | Suspension - Brakes - Steering | 6 | 12-07-2004 07:06 PM |
