Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 7 Quart oil pan and Dipstick Problem
Old 09-11-2008, 01:54 AM
y2k600f4 y2k600f4 is offline
I think the dipstick is 2" shorter than it should be. I need a 21" dipstick to go along with the 6.5" tube for the oil level to correctly read at 7+1 qts. Are they available ? I know I can always cut 2" off the tube but wanted to check if this was correct first before I did anything. Thanks.
