7" vs 8" Dual Booster - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2012, 02:59 AM
Is there that much difference between a 7" and 8" dual boosters power assist capability? I've got about 16 vacuum at idle will I gain much by switching from a 7" to an 8" dual booster?
Old 11-09-2012, 07:35 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You will gain about 100 psi by using the larger booster. Whether or not it will be enough to satisfy whatever the deficit is, I cannot say w/o more info.
Old 11-26-2012, 11:39 PM
Got stock S10 front disc with S10 Blazer rear disc, good stopping power would like more, was thinking about changing to an 8" dual booster. The MC is a Corvette syyle with aftermarket under-the-floor and mount/pedal.
Old 11-27-2012, 06:15 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Was the caliper bore diameter taken into account when the MC was bought? I ask because there are several different 'Vette MC bore sizes available.
At least some S10 calipers were the low drag type that used the stepped bore MC. Do you have more pedal travel before braking begins than you like?
Have you looked at the pedal ratio?
Old 11-27-2012, 07:32 AM
The MC bore is one inch and the pedal assembly is an aftermarket under the floor. I've got 2lb residual valves on front and rear, no excessive pedal travel. Braking response is good would like a little less pedal effort.
Old 11-27-2012, 08:32 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Less effort at the pedal w/more pedal travel can be done by a pedal ratio change. This is the easiest thing to try and I would do this first before changing the bore size, etc.
Old 12-17-2012, 12:24 AM
Just installed an 8" dual and what a difference, now I have the braking response I wanted well worth the 59.00 for the booster.
Troubleshooting 8" Dual Diaphragm Booster CJ8Hokie Suspension - Brakes - Steering 0 04-14-2011 02:27 PM
"electric vacuum pump for the brake booster" Joe DA Suspension - Brakes - Steering 19 01-28-2009 10:13 AM
7" dual diaphragm Booster Silverfox031 Suspension - Brakes - Steering 1 07-07-2006 02:34 PM
Master cylinder to fit 8" dual booster jcarter Suspension - Brakes - Steering 7 05-25-2006 02:13 AM
"Rattle Can" Painting a Gold Iridated Booster acr Suspension - Brakes - Steering 6 12-07-2005 09:25 AM
