Sounds like the computer (CCC3) connector.You need to get a distributor with mechanical and vacuum advance on it.Unless you want to run a computer controlled carb and distributor.
Ecu
So... if I got this right, that four wire harness plugs into some sort of computer that was located on the Chevy van? So I did a search of the statewide auto recyclers looking for the computer that would control my distributor. I came up with a whole bunch of information I don't understand. Can someone give me a crash course? I found what is called a "Computer Box Engine" or "Engine Computer" and finally, and ECM or a ECU..... Can I assume these are all the same thing? How do they work? Any/all help would be appreciated.... Thanks
After further review
It seems that as well as the computer, I will need all the sensors that feed it information as well.. I then think I would be better off finding a distributor with a vacuum advance... any suggestions?
Thanks... it is pretty much the same advice I have gotten from several other sources as well... I have asked techs at both Summit and Speedway for advice and both have been real good on this build. I might also look around for a used distributor but prefer a new carb so I don't have to rebuild and take a chance...although a new distributor is not that much money either.... Thanks for the advice.... This is not going to happen until next fall because I do like to check out all the swap meets in the summer.... appreciate the help...
| Recent Modern Electronic Engines posts with photos |
| What are all these wires | 2000jack | Electrical | 5 | 03-09-2012 10:35 PM |
| c6 wires | ajbcc2 | Transmission - Rearend | 2 | 01-23-2010 08:38 AM |
| where do these wires go | dearta223 | Electrical | 2 | 08-01-2009 09:32 PM |
| which wires are which?.... | sc2dave | Engine | 5 | 08-21-2005 07:06 PM |
| 3 wires are better than 1 | 32vicky | Hotrodders' Lounge | 2 | 11-03-2003 06:40 PM |
