70-1/2 RSS Camaro Head spec needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2002, 10:20 PM
Post 70-1/2 RSS Camaro Head spec needed
Does anyone out there know what the head spec were for a 70-1/2 RSS 350 (10:25:1) Camaro would be? Especially the cc's. I believe the part number is E21 70 8947041. I am in the process of getting this motor stroked to a 383. Any recommendation on compression ratio?
Thanks,
Mitch
Old 04-30-2002, 02:45 AM
Tom Tom is offline
Post
041 heads are 64cc with either 194/150 or 202/160 valves these are fulie type heads good for higher compression applications
Old 04-30-2002, 09:04 PM
Thumbs up
Good info on the heads.. Planning to use these on a 383 stroker. Should I keep the 10.25:1 ratio or lower it?
Mitch
