70-72 GTO Tub/Body - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2011, 11:39 AM
GMCTRUCKS's Avatar
70-72 GTO Tub/Body
OK members don't know if this might help someone on a build but I found this item a convertible GTO body/tub and it was going for $700.00 dollars but it ended info below im sure you can write the seller on ebay.
Good luck! Roland
1970-72 GTO Convertible Tub/Body (110667014782)
Member id eliminator_scj
g-body to b-body rear end swap? 95coughnut Transmission - Rearend 5 04-25-2008 01:46 AM
gm g-body rearend into a-body swap camaro guy Transmission - Rearend 1 03-28-2007 08:05 AM
32 Ford body, firewall and body bolts heyjude076 Body - Exterior 5 11-20-2006 05:57 AM
3rd Gen F-body rear discs on 65 A-body 12 bolt? smallblocker2 Suspension - Brakes - Steering 7 03-22-2006 12:51 AM
g-body to a-body rear end swap? 85Sierra Transmission - Rearend 3 11-24-2005 01:34 AM
