70-77 camaro wheel stud size? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2010, 05:40 PM
need strog32 chevy front doors
Last journal entry: Tbd
Where can i fine out where to get longer studs?? Im running a camaro rotor on my 32 chevy and need longer studs to run centerline wheels . Where to i find out the dimensions of the correct stud, like shaft size and such with out removing the original stud
Old 05-04-2010, 07:13 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The stud size is 7/16-20 RH. Most Camaros from that era use a 0.580" knurled diameter stud for the disc brake hub. JEGS has ARP P/N #070-100-7702 that is a 0.580" knurl x 2.875" long stud, $10 per wheel (set of 5 studs). SUMMIT has studs in 2.875" length for $12.95 per wheel.
Locally, any parts house that carries Dorman studs will have these as well- just check the knurl size first to be sure of what you have.
Good luck.
69 camaro steering wheel installation brads1966 Suspension - Brakes - Steering 1 12-26-2007 04:14 PM
Clip the front of a 59 Chevy pu with a 70 Camaro Front clip? Will it work? classicappraiser General Rodding Tech 6 10-16-2006 12:05 PM
Wheel stud replacement method jpd37 Transmission - Rearend 3 06-18-2003 11:07 AM
ford 9" rear housing for 70 camaro richrat Transmission - Rearend 1 05-03-2003 10:56 PM
rear wheel locked on 77 vette john69 Transmission - Rearend 6 10-28-2002 12:23 PM
