70 AMX Brakes needs brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2005, 02:17 PM
Ratdoggy's Avatar
Hammer torch chisel...
Last journal entry: Getting there
Hi
My neighbor has a AMX that he asked me to help him with ( I have heat in my garage ). To do the rear brakes do I need a puller to remove the drums or does it come off w/o tools? We are also changing brake lines,calipers,cylinders etc... Anything to watch out for ? I've never worked on an AMC before so I just wanted to look for any pitfalls
Thanks Mike
Old 11-27-2005, 10:14 AM
As the Moderator here......I have watched this slowly fall down the listing without a response.......
I do not know about the AMX.........but on some of the slightly earlier American Motors products......they are like the early model Fords........and use a tapered axle/hub set up. They require a puller. You had to remove the nut on the end of the axle shaft...( good luck on that ) and then use a puller that hooks up to the 5 wheel bolt pattern ......and then it worked like a harmonic balancer puller.
Let us know.........if it worked out for you....
Old 11-27-2005, 11:28 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Geez, it has only been on here 20 hours.......LOL
I don't know specifics about that car rear end.
Old 11-27-2005, 12:08 PM
Ratdoggy's Avatar
Thanx
I thought I might need a puller and the manual doesn't mention it. I'll
try it the standard way;remove tire and hopefully the drum falls off. If
not I won't force it
Thanx
Once again.
Mike
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 10 01-24-2011 11:09 AM
Removing Power Brakes from 70 Camaro Rick Beil Suspension - Brakes - Steering 3 10-06-2005 07:19 AM
G body with manual brakes - it works! - pics dh79 Suspension - Brakes - Steering 7 08-27-2005 10:55 PM
Brakes locking up in non ABS system nprfan Suspension - Brakes - Steering 9 08-24-2005 12:37 PM
70 olds cutlass brakes 1970 olds man Suspension - Brakes - Steering 3 02-10-2005 12:31 AM
