70 camaro needs needs new pans, some pics - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2007, 04:03 AM
Gladis's Avatar
I am very excited, found a 70 Camaro, 2000 bucks, doesn't run, needs new front floor pans and trunk part of the trunk pan. Actual description follows:
COMPLETE PROJECT. NEEDS LOTS. WILL NEED AT LEAST FRONT FLOOR PANS AND PART OF REAR TRUNK FLOOR. POWER STEERING AND BRAKES . 4SPD . 10 BOLT. LIKE NEW BFGS IN REAR. REAR SPOILER. BEEN OFF ROAD FOR YEARS. THIS IS A NON RUNNING CAR .
My BIG question is how much do new floor pans cost? Can I do it myself with redneck power, and a welder? If the cost is insane I can't buy this car, if not I need to get a move on it now, i.e. I've been looking for 70 Camaro for 6 months in my area and haven't found jack till now. Oh and it's a Muncie 4 speed.
ID:	19978   Click image for larger version
ID:	19979   Click image for larger version
Old 03-29-2007, 04:14 AM
Gladis's Avatar
there appear to large holes in the floor pan, how bad is this? How much $$$ to fix that?
Old 03-29-2007, 04:49 AM
poncho62's Avatar
Wiki Edits: 5
The pans will probably cost a few hundred..........maybe $500...........
Hows the rest....engine turn over?
Old 03-29-2007, 05:21 AM
crash70rs's Avatar
Last journal entry: Going Slow.. and steady?
If the floor pans and truck are rusted i'd be suspect of other parts as well.
I have a '70 with solid floors and trunk, but rusty everything else.
My advise is to take a real good look at everything else if you haven't already (check the radiator support. - mine was a toast) and bring a magnet to find bondo (I think mine is sculpted from it ).
Check out www.yearone.com and www.goodmarkindustries.com, they should have all the parts. Year one iskinda pricey but it'll get a ballpark.
Otherwise anything could be done with a little patience!
Old 03-29-2007, 05:23 AM
Gladis's Avatar
not sure if the motor turns over or not, betting it doesn't, but I'm going to pull the 350 I just put in my trans am. The car has been sitting for several years, drag car project that never got off the ground. Hoping it was stored in a barn, garage, inside anything. After I pull the 350 I'll sell the trans am. I'll probably either get a beater in the mean time, or tough it out on my 18 speed. It's still a bit rainy though.
Can I being an idiot, do the pans myself? What will I need? The whole deal with this is I was looking for a parts car that had a muncie 4 speed so I could put it in my trans am, then I ran across this and I thought this car is almost my dream car. So why not get this and sell the trans am.
I am also going to try to talk this guy down as much as possible. What's reasonable? I know that's hard to answer and very subjective.
Old 03-29-2007, 05:25 AM
Gladis's Avatar
magnet, great idea, thanks, I'll be sure to check the radiator supports.
Old 03-29-2007, 05:32 AM
Gladis's Avatar
how do I check to see if it's posi or not?
Old 03-29-2007, 08:02 AM
That looks like a great project. I sent you a PM with a source of information on your car.
Does it have a numbers-matching motor?? What trim level is it (Z28, SS, LT, etc.)??
Old 03-29-2007, 08:20 AM
FIREBIRDTONY's Avatar
Last journal entry: the rear body panel
these are pics of my floor. i bought 2 full floor pans for 140 a side from ricks camaro in athens ga. i droped them in and traced them with a grease pen i cut about an inch and a half lower and tack welded them in and welded all around. i supported the car on jack stands. and the door gaps were close befor. after i welded them in and sat the car on all fours the gaps were perfect! i picked up a miller matic welder for 175 dollars at a pawn shop it looked new! i was a body man for 11 years but its been that long since i practiced my trade. i love body work and decided its time for me to have some toys. good luck on your project!
ID:	19985   Click image for larger version
ID:	19986   Click image for larger version
ID:	19987   Click image for larger version
ID:	19988   Click image for larger version
Old 03-29-2007, 02:01 PM
BIGSKY's Avatar
See project in Photo Album
The nice thing about floorpans is unless you are building a show queen you can weld them in and in the process learn enough to have some skills when it comes time to do quarter panels and such. I had never done any body welding when I started on my truck resto, and besides the extra time I spent running the grinder due to my amateur welding, it turned out great.
Switching 71 Camaro 10 Bolt Rear End To Disc Brakes TORI1 Suspension - Brakes - Steering 1 04-13-2006 03:38 PM
72 camaro nose on a 78 camaro roy383ci Body - Exterior 3 02-25-2006 05:59 PM
original 70 camaro window "felt" no longer made bullheimer Body - Exterior 0 04-01-2004 11:10 AM
New pics of my primed camaro Rubberman2003 Hotrodders' Lounge 5 11-19-2003 09:31 AM
ill post camaro pics when i get home Rubberman2003 Hotrodders' Lounge 2 08-17-2003 06:21 PM
