70 chevelle driveshaft length - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2005, 07:56 PM
TASHAN's Avatar
Last journal entry: Vortec L31/880 383 project (16)
chevelle th400 driveshaft lenght
can anyone tell me the lenght from center to center of the u-joints on a driveshat for a 70 chevelle with a 4" tailshaft th400?
Old 02-18-2005, 08:25 AM
Secure the proper slip yoke and install into the trans until it stops. Pull the yoke back out 1" to 1 1/4". Measure from the centerline of the front joint to the centerline of the pinion yoke joint.
Old 02-18-2005, 08:36 PM
TASHAN's Avatar
70 chevelle driveshaft lenght
I asked the other day but I guess something happened and I never got to see an answer,.... does anyone know the lenght of a driveshaft for a 70 chevelle from center to center of the u-joints? the trans is a th400 w/4" tail, and the rear end is a 10 bolt.
Old 02-18-2005, 09:55 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
please see your original post below for a response.
Tony
Old 02-18-2005, 09:59 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
back to the top
Old 02-19-2005, 07:35 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
I merged the two threads together.
Old 02-19-2005, 08:47 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I unlocked the thread to allow further discussion on the subject.
Old 02-19-2005, 05:09 PM
TASHAN's Avatar
I dont have the engine or trans installed,. not till at next weekend the soonest, but I want to order a driveshaft now so I have it by that time. Thats why I was wondering if anyone knew. But If I have to wait I guess I will.
Old 02-19-2005, 11:39 PM
Wait.
Guessing on driveshaft length is ridiculous, not to mention expensive.
Yoke variances, suspension height, and drivetriain mounting can and will afffect this. Patience !!
Old 02-20-2005, 09:02 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by Chazmac
Wait.
Yoke variances, suspension height, and reverting mounting can and will afffect this. Patience !!
what he said..... drive shaft work ain't cheap.
It sounds like you are bolting the vehicle together for the first time......do it once correctly
Old 02-20-2005, 09:45 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
I don't remember locking it , was one of the originals locked before I merged the two posts?
Anyway, Chazmac and Crosley are right, driveshafts are NOT cheap.
I had a quote from a nationally recognized driveshaft specialist for over $1200 for my truck because they wanted to make one out of carbon fiber for the length I needed.
The local driveshaft shop gave me a quote of $120 with the same guarantee the national guy put on his, and the local guy built it out of steel.
Like they also said, get the engine and transmission mounted in the car before you measure for the driveshaft.
Measure twice, pay the guy once.
Old 02-20-2005, 08:32 PM
TASHAN's Avatar
Im doing a fully stock setup. I can get a driveshaft for about $25-70 used. I just wanted someone with the same car and specs to gimme a lenght. This is the first time Ive done THIS car,.. certaintly not the first time building a car. SBC and BBC have the same mount to transmission lenght and the 70 had both 4" tail th400 and both sbc and bbc engines. Its not a custom fit. Ive already found an answer from another source. Thanx though.
67 chevelle 12 bolt fit in 70 chevelle? 70chevelle327 Transmission - Rearend 11 09-11-2006 07:52 AM
454 or 427 for 70 Chevelle? f100beatertruck Engine 3 11-25-2003 05:29 PM
69 chevelle driveshaft... jackyandjoe Transmission - Rearend 2 06-20-2003 08:49 PM
rear coil over suspension for 70 chevelle? trav 70 Suspension - Brakes - Steering 1 12-21-2002 03:46 AM
