throttle bracket
Seems to me that there is no one car that will have the bracket you need-mainly because of the Olds Quadrajet.You should study the throttle mechanism on the 2-bbl.to get an idea for swing distances to adapt the throttle arm on the Olds Quadrajet to suit your purpose.Just a thought.Maybe even attatch the 2 bbl throttle arm to the Quadrajet-
thanks for the reply, I'm pretty sure the throttle linkage on the Olds carb is the same as a Chevy carb, I seem to recall swapping an Olds carb onto a sbc before, however the car was already set up for a quadrajet.
At a glance the linkage on the two barrel looked the same as the quadrajet linkage, it just seems like it is further forward on the intake. Chris |
Throttle cable etc-
Will the kickdown cable reach the correct place on the carb without the bracket?or is it now too short?you might need a longer kickdown cable.Most of the time I have good luck with chevy truck brackets.
You may need something like this...http://store.summitracing.com/partde...5&autoview=sku
Thanks again for the replies,
eyesore, the kick down will reach the carb, the cable is plenty long, its just when its in the bracket that it doesn't fit, even when its adjusted all the way out its still placed too far back. 73oldsman, thanks for the link, we may have to go with something like that if we cant find a factory bracket for the car. one thing about this hobby, you never stop learning, sometimes the smallest details can trip you up. Chris |
| 67 chevelle 12 bolt fit in 70 chevelle? | 70chevelle327 | Transmission - Rearend | 11 | 09-11-2006 07:52 AM |
| 70 Chevelle | roosterjab | Introduce Yourself | 3 | 11-30-2005 11:57 PM |
| Moroso Throttle cable Bracket | skeeveman | Engine | 2 | 02-14-2005 07:27 AM |
| q jets for B/O/P and caddy throttle bracket | COCHEV | Engine | 2 | 07-15-2003 07:36 PM |
| rear coil over suspension for 70 chevelle? | trav 70 | Suspension - Brakes - Steering | 1 | 12-21-2002 03:46 AM |
