'70 Ford 302 vacuum advance question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2008, 07:28 AM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
There are two vacuum ports on the vacuum advace can on the distributor (old school single points type) the one port works acts as it should and advances with vacuum applied (suck on it), but the other port doesn't seem to do anything but leak. I have a couple of these distributors and they both do the same thing. Is only one vacuum line required?
Thanks
Old 03-17-2008, 10:06 AM
onebadmerc's Avatar
I need a bucket of arc sparks
The front one is used for the distributor advance. The rear port is used for when your car decelerates. It is suppose to reduce advance when you are decelerating and prevent loading up on fuel and backfiring, though I am not 100% certain on this. I know on my my 73 Mustang I just put a vacuum cap over the back port and it runs fine.
Old 03-17-2008, 01:15 PM
agree with one bad merc,
dual vac advance (push and pull on the centrifugal) was on early 70's cars when they were trying to make cars work decent with very low CR, only 87 octane and early smog systems....
food for thought:
if you don't know for sure that it has been rebuilt for bearings and plate etc....(it's 40 years old+)....and for some reason you want to stay with points.... just buy a pre-70' rebuilt 289-302 dist ($50?) and use it (otherwise "good luck" trying to curve it with a worn plate and bearings)
Old 03-17-2008, 08:04 PM
Arrowhead's Avatar
Wiki Edits: 5
Makes sense to me. I'll give it a whirl that way. Thanks!
454 Ignition Timing Question leejoy Engine 56 09-13-2008 09:40 AM
ignition timing bad502 Engine 21 02-20-2006 07:57 PM
vacuum advance dongee54 Engine 2 04-02-2004 10:48 AM
distrib question: vacuum vs mech advance JUSTINH Engine 4 08-20-2003 12:21 PM
vacuum advance problem tonylsg Engine 10 12-13-2002 09:32 AM
