Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 70 GTO front bumper
Old 04-16-2011, 05:59 PM
freethinker52 freethinker52 is offline
Originally Posted by timg624
I am having a nighhtmare of a time trying to line up my front bumper (70 GTO) with the fenders. It seems that I have to pull the bumper all the way up to the end of the mounting slots for the tops to align with the fender but then the bottom of the bumber is over a inch away from the lower part of the fender !!
I am going nuts with this. A couple of thoughts I had is that when I mounted the body to the frame, maybe I didnt have the body back far enough on the frame, or, did I mount the radiator support wrong (which holds the fenders also) thus causing improper height of the fenders in the front of the car.
If anyone can send me a picture of the proper way to install the bushings on the radiator support, that woudl be a great start to eliminate that first.
Thanks for any input,
sounds like a radiator support or ft bushing problem. is it a repop support? they dont fit right.
