70 nova rear end 355'swhat no.splines - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2002, 12:56 PM
New Member
Post 70 nova rear end 355'swhat no.splines
I have a 1970 nova rear end with 355's, and want to go to 373's, is there anyway to tell the number of splines without taking the thing apart
or losing the preload thanks oldnable <img src="confused.gif" border="0">
Old 07-17-2002, 02:15 PM
New Member
Post
I will answer my own post, I talked to Luke at randys ringand pinyon he said the yoke nut will be 1 and 1/8 th on a 8.25 25 spline and 1 1/4 on a 8 1/2 30 spline hope this helps someone out there oldnable
Old 07-17-2002, 02:39 PM
axle bastard's Avatar
you're killin me buck!
Post
you can take the pinion yolk off, just don"t put it back on more than 150 foot lbs. you won't loose the pre load and you won't kill the crush sleeve.
i have done this several times to change seals, and NEVER have i had one bounce back.
Old 07-17-2002, 03:59 PM
New Member
Post
thanks axel.
Old 07-17-2002, 08:19 PM
Post
no sweat, thats why we come here+ "no topic"
Old 07-18-2002, 12:39 PM
New Member
Post
thanks again axel, I took off the yoke and it is 25 spline 8.25 now I can get my gears. oldnable
