70 Pontiac 400 4BBL - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2010, 12:23 PM
70 Pontiac 400 4BBL
Can some one tell me if this engine used ported or manifold vacuum for ignition advance? I am not sure what year Pontiac switched to ported advance.
Thanks,
BT
Old 06-14-2010, 06:22 PM
DoubleVision's Avatar
If the catalyst is still present it will say disconnect vac advance when setting the base timing which means it uses manifold advance. However if the catalyst is absent, then I would try them both and stick with the one it ran better with. My guess would be it uses manifold vacuum.
Old 06-14-2010, 06:29 PM
Hippie's Avatar
Last journal entry: HEI comparison.
Second that.
How to make more power in a pontiac 400 psmvchaser Engine 15 05-17-2010 09:10 PM
Pontiac 400, XF Code Houston54 Engine 5 11-02-2007 05:32 PM
pontiac 400 camaro guy Engine 4 04-04-2007 05:28 AM
Pontiac 400 wider than Chevy 350 Goatman01 Engine 3 01-31-2007 12:11 PM
70 pontiac grand prix feggesc Engine 1 01-25-2007 10:00 AM
