69-70 Pontiac brake rotors are on there own. Nothing else will work. The outer bearings bearings are differant for one. Have you actually tried this?
69-70 uses a #2 outer and #5 inner bearing 71-76 and most other full size use a #3 outer and #5 inner. Most gm's use a combination of 2 and 6 or 3 and 5. #2 .750 id, 1.781 od #3 .8437 id , 1.969 od #5 1.375 id, 2.563 od #6 1.25 id, 2.328 od each maker has differant prefixes, but they usually use the same basic number. Sorry to get so technical, I just wonder how your getting past the bearing differance? Back to the original question, it seems all the available new rotors have run out. There is one company , Scarebird that makes disc brake brackets for the non mainstream cars. At one time someone was looking for him to make some brackets for those spindles, yes it sounds funny to make a disc conversion for a spindle that already has disc brakes , but since no rotors are available maybe an option with using a ready available rotor or cut your rotor down to a hub and slip a rotor over it. . Another option would be to find a pair or drum spindles and put his bracket that is already made for those and convert those over to disc brakes. I have an older kit that I have on 63 spindles available that would work on your 70. The old popular swap before disc brake kits came out was to put the 69-70 setup on the earlier 60"s Pontiacs. My 63 drum spindles reuse the drum hub and use a 11" rotor over the top . The newer kits use a 12" rotor like the original rotor. Or find a good used set ? Last edited by chieftain; 04-30-2010 at 09:22 PM. |
i belie ve that I read somewhere that vette rotors can be used on the original hubs. these hubs use a different bolt that presses thru the rotor from the back side into the hub and mounts the wheel directly to the hub. wish I could remember where I saw it.
I believe it involves using the drum spindles w/rear 'Vette rotors and longer studs- but this needs to be verified.
you have the 5x5 BP correct?
1991 the bolt pattern for the caprices reverted to the 5x5 like the previous wagon and police package. you might be able to use some front rotors from a 91-96 caprice. alot of the b body stuff stayed the same from the 70-96.
| this is a saver.... GM build codes | TooMany2count | General Rodding Tech | 24 | 11-23-2009 09:36 AM |
| Full Manual Valve Body TH-400 | Chezelle | Transmission - Rearend | 3 | 06-13-2003 06:47 PM |
| TH350 Modify stock valve body to full manual | Mr. Horsepower | Transmission - Rearend | 7 | 05-26-2003 10:21 AM |
| '70 Buick GS body parts | speedpro | Body - Exterior | 1 | 11-07-2002 11:56 AM |
| Size of Ford T-bucket body? | wannabe | Body - Exterior | 0 | 09-28-2002 07:42 PM |
